kwangomango
Feb 18, 2021Tutor
ORBI RBS/RBR 40 UPNP not working when device connected to satellite
I'm having exactly the same issue as described in this thread: https://community.netgear.com/t5/Orbi/ORBI-UPNP-not-working-when-device-connected-to-satellite/td-p/1544717 but the solution of dis...
kwangomango
Feb 18, 2021Tutor
Hi
UPNP is already enabled on my router. This issue i'm describing is that the Orbi satellite is not forwarding the requests to the router.
vajim
Feb 18, 2021Master
well I'm guessing it did work and now it doesn't...??
if that's true what changed?
firmware?
- kwangomangoFeb 18, 2021Tutor
Thanks for your assistance but can i suggest you read my original post again and the post i have linked to so that you can be clear what the problem i'm facing is.
- vajimFeb 18, 2021Master
ok
- vajimFeb 19, 2021Master
kwangomango wrote:Thanks for your assistance but can i suggest you read my original post again and the post i have linked to so that you can be clear what the problem i'm facing is.
any progress on this?
- kwangomangoFeb 19, 2021TutorNo one has been able offer any suggestions to fix it just yet.
