kwangomango
Feb 18, 2021Tutor
ORBI RBS/RBR 40 UPNP not working when device connected to satellite
I'm having exactly the same issue as described in this thread: https://community.netgear.com/t5/Orbi/ORBI-UPNP-not-working-when-device-connected-to-satellite/td-p/1544717 but the solution of dis...
BoilerPlate
Feb 18, 2021Apprentice
You may want to get help from other more experienced and informative users here in the forums. User beware>vajim.
kwangomango wrote:I'm having exactly the same issue as described in this thread:
but the solution of disabling the daisy chain topology does not fix it for me...
I have the Orbi RBR/RBS 40 pair in access point mode connected to a TP-Link VR2800 router. If i connect my Synology NAS wired to the RBR40 hub it can detect the VR2800 and happily set the upnp port forwarding rules. However if i connect the NAS wired to the satellite it is unable to detect a compatible upnp router. Everything else seems fine except this upnp issue. Both the hub and satellite have the latest firmware installed.
