Bill____
Apr 06, 2018Apprentice
Orbi RBS/RBR 50 Version 2.1.3.4 and Apple homekit iDevices and Philips Hue problems.
I have updated to firmware version 2.1.3.4 and have noticed some homekit instability. I have several iDevices Switches which have become intermittent and no other changes than the router firmware. ...
Rattler
Apr 10, 2018Guide
I'm using Firmware 2.1.3.4 using Orbi as a router and just had an Apple Bonjour issue. I was updating printer drivers on all my macs and the laptops connected via WiFi to the Orbi Satellites did not recognize the hard wired network connected printer. When connected via WiFi to the Orbi Router, Bonjour was recognized. Also recognized on ethernet hard wired computers as well. I tired both Wireless and Wired backhaul. I tried restarting the satellites and re-syncing them. The reason I bring it up here is that maybe Homekit uses Bonjour and the Satellite connected devices had a problem. Just another datapoint. I'm not really willing to set back my firmware to see if that fixes it for me as it only a set up problem I can correct by moving the laptop only when adding the printer. Printer works fine once set up.
eljarviso
Apr 10, 2018Luminary
Netgear is probably blocking mDNS broadcasts to the satellite. This also explains my previous problems with AirPrint. How can they push out these changes without testing. You’d swear the entire orbi product line is supported by one coder in his moms basement who only has an android phone.
If netgear doesn’t fix there junk software I’m going to grab a second asus ac87u, update to their mesh firmware, pack up my orbi, and personally drive it down to netgear headquarters and ram the whole thing up their CEOs ass.
- Bill____Apr 12, 2018Apprentice
I may have been premature or in error stating that I had trouble with Philips as I didn't get a chance to reproduce it. However, the iDevices definlitely have a problem with this newer firmware.
I just spent about two hours on the phone with a patient but very pleasant support person who walked me through the various steps to capture information to give to the tech team.
I now have everythng rolled back and working but hopefully the information captured is of use to finding a resolution to the problem.
Although it was a lot of trouble to get to support with the barriers put in place to get money (and still wondering why no response from mods here), the two support people I dealt with were very pleasant and helpful towards getting information required for a solution.
- epsilonkoreApr 12, 2018Apprentice
I am running 2.1.3.4 on my Orbi 53 using wired backhaul. I also have 3 AppleTV 4K's running 11.3 (and during the last two days upgraded to 11.4 beta to see if it fixed my issue, it didnt), Phillips Hue with latest firmware on hubs and bulbs, numerous iHome, Incipio, August, Nanoleaf, Chamberlain, and Ecobee HomeKit devices in my house. I have not noticed any dropped Homekit devices but I HAVE noticed they are now extremely slow to respond. When refreshing my Homekit page it takes up to a minute to get the "updating" to resolve to a standard status. When I tap a device to toggle its status or change a color of a bulb it is very slow to respond. Note this is while my iPhone/iPad is in WiFi mode (cellular mode always has lag, WiFi never did).
- AC641Apr 12, 2018Luminary
Having had zero issues in a little over a year I have recently been experiencing issues with WiFi dropouts on my iPad when connected to the Satellite. Additionally, I have seen issues with my Philps Hue lights in that Routines I have setup fail to function. Both these issues have only occurred after installing the v2.1.3.4 firmware. Having read this thread I have downgraded to v2.1.2.18; I had previously had zero issues with this or any other firmware version. I'll report back in a couple of days as to whether this has cured the issues.
- john_roweApr 12, 2018Guide
I think eljarviso nailed it.
I have multiple HomeKit devices including Nanoleaf, Hue and VOCOlinc. They all worked reliably before the 2.1.3.4 update. After the 2.1.3.4 update most devices started showing up as unresponsive, and they wouldn’t respond to Siri.
I took a look at my network and found that all my _hap._tcp mDNS devices were constantly disappearing and reappearing from the network. This is how HomeKit communicates with devices, and them disappearing from the network will make them appear as unresponsive.
So it appears whatever the Netgear folks did to try to fix the Orbi crashing issue caused by Chromecasts appears to have broken other devices.
- AC641Apr 13, 2018Luminary
Well to update following my firmware downgrade:
The WiFi dropouts on my iPad when connected to the satelite have ceased.
The Philips Hue issues remain so it's going to be a Hue Hub reset and reinstate everything from scratch when I have an hour or so to spare. It's a real pain as there's no way to back-up settings with the Hue system - a major failing.
- Bill____Apr 13, 2018Apprentice
I had to pretty much reset my Philips Hue also after I downgraded.
It was unresponsive and just not really working.
Certainly a lot of work to go through...updating, finding problems, trying to fix them, then downgrading and having to fix problems again.
All working fine now....on the downgraded firmware.
- gforce216Apr 13, 2018InitiateSame issue with my Lutron, MyQ and Ecobee. Rolled back the firmware based on this thread and it all works perfectly again.
- Bill____Apr 14, 2018Apprentice
Netgear Tier 3 support are still working on this.
I don't know why I got an email that some comment about "resetting" everything was accepted as a solution. This problem is not solved and it will only be solved by the firmware being fixed....until now, the "solution" is to revert back to an older version, which is actually a workaround and not a solution.
- OutGolfnApr 15, 2018GuideI am also having the connection issues with my iHome smartplugs immediately after updating to V 2.1.3.4 Hopefully the next public release fixes this error within the firmware.
Bill thanks for your effort in reporting this to the Tier 3 Tech at netgear. I’m hopeful they can identify and fix this Apple HomeKit issue. - Bill____Apr 15, 2018Apprentice
I am glad to help out but am also pleased that many other people have mentioned their problems so that Netgear can get a grasp on how widepread it is. I do wish they'd pull the update from the download list, or at least put up a warning about the issues.
No updates on the weekend, but I have every reason to believe they are working on it as I did get some questions as things progressed.
- AC641Apr 16, 2018Luminary
The issues with my Philips Hue lights were resolved without having to reset the hub and set it up from scratch. A power cycle was enough to correct the issue following the Orbi firmware downgrade. All has worked perfectly for 3 days now.
- john_roweApr 23, 2018Guide
It's been a couole of week. Any updates on this?
- Bill____Apr 23, 2018Apprentice
Nope.
Not a word.
The firmware that was giving all the problems is still available as a download too.
Well, I can't say I'm surprised.
About 10 years ago I swore off buying Netgear products. Looks like I have to learn that same lesson every 10 years or so.
Thanks for keeping on them Bill.
I appreciate the support of the other posters.
I like the Orbi system, I just don't like failed firmware updates, especially two in a row, and unresponsive support.
I can tell you that the two support people I talked to were great, didn't make me do any stupid things, etc. But then it got passed on to Tier 3 and I don't hear from them..
- SimonSaysDanceApr 24, 2018Aspirant
For what it's worth, this fixed my chromecast issues (24 hours with no dropouts, fingers crossed).
On the satellite, enable telnet from debug.htm, login and run:
echo 1 > /sys/devices/virtual/net/br0/bridge/multicast_querier
- Bill____Apr 24, 2018Apprentice
Thanks for the information.
I was going to wait for a new firmware update instead.
I see that version 2.1.4.10 is out now..no mention of the problem being solved from what I can see...
In case anyone is wondering, I tried version 2.1.4.10. I am back down to version 2.1.2.18.....
- whittleApr 24, 2018Guide
Bill____,
Thanks for the information on your experience with 2.1.4.10. I am running 2.0.1.4 waiting for a resolution of the HomeKit issue. I hope NetGear puts some resources toward fixing the problem. I also hope my system does not auto update...
Since a new release is going out today without a fix, I imagine it will be at least two or three weeks before there is any hope for a solution to the HomeKit woes.
-whittle
