Bill____
Apr 06, 2018Apprentice
Orbi RBS/RBR 50 Version 2.1.3.4 and Apple homekit iDevices and Philips Hue problems.
I have updated to firmware version 2.1.3.4 and have noticed some homekit instability. I have several iDevices Switches which have become intermittent and no other changes than the router firmware. ...
PeytonBrandt
Apr 25, 2018Star
Wait, are you guys really having luck with 2.1.2.18? My HomeKit devices are showing up with a "!" next to them indicating they're not responding, but I'm still able to control them.
cheshbr
Apr 29, 2018Apprentice
I have had less than a month’s experience with my Orbi RBK500 system, and I think it’s stable running v2.1.2.18, with a wired backhaul too. I have four Lifx smart bulbs that work brilliantly (pun intended) with Alexa, Google Home, and Apple HomeKit. I had tried 2.1.3.4 and the newer 2.1.4.10 but both of these gave me “unresponsive” against the Lifx in HomeKit. Right now, everything seems to be working, including roaming, so I will stick with 2.1.2.18 until the bugs are fixed.
By the way, I prefer to install my firmware changes manually, satellite first and when all seems to be working, I switch both Orbis off and on again, check the attached devices on the satellite, and if there’s anything that should, or should not, be running on the satellite, I power cycle these devices until they are running where they should be. Finally, I use the Netgear Genie’s Network Map to check signal strength to verify that the Orbis and attached devices are optimised. (If the signal strength is significantly less than 100%, it’s an indicator that the attached device is on the wrong Orbi).
Good luck
- Jeepfreak1983Apr 29, 2018Guide
Thank you i have tried manual as well more like a flash but it will not allow and says the firmware is incorrect plese get firmware again and make sure it is the correct firmware for this product and i was trying to do satlite first
ok so I have got the flash to work I also went back to 2.1.2.18 both satellite and router the issue i had with file type was i checked the satellite box and uploaded it in the router box nex im try to work on blocking auto updates seen this.
https://community.netgear.com/t5/Orbi/Firmware-V1-12-0-18-Discussion/td-p/1320421/page/5
this has been a nightmare. I am very thinkful for this community as i was pulling my hair out over this thank you all for your help
