Bill____
Apr 06, 2018Apprentice
Orbi RBS/RBR 50 Version 2.1.3.4 and Apple homekit iDevices and Philips Hue problems.
I have updated to firmware version 2.1.3.4 and have noticed some homekit instability. I have several iDevices Switches which have become intermittent and no other changes than the router firmware. ...
cheshbr
Apr 29, 2018Apprentice
I have had less than a month’s experience with my Orbi RBK500 system, and I think it’s stable running v2.1.2.18, with a wired backhaul too. I have four Lifx smart bulbs that work brilliantly (pun intended) with Alexa, Google Home, and Apple HomeKit. I had tried 2.1.3.4 and the newer 2.1.4.10 but both of these gave me “unresponsive” against the Lifx in HomeKit. Right now, everything seems to be working, including roaming, so I will stick with 2.1.2.18 until the bugs are fixed.
By the way, I prefer to install my firmware changes manually, satellite first and when all seems to be working, I switch both Orbis off and on again, check the attached devices on the satellite, and if there’s anything that should, or should not, be running on the satellite, I power cycle these devices until they are running where they should be. Finally, I use the Netgear Genie’s Network Map to check signal strength to verify that the Orbis and attached devices are optimised. (If the signal strength is significantly less than 100%, it’s an indicator that the attached device is on the wrong Orbi).
Good luck
Jeepfreak1983
Apr 29, 2018Guide
Thank you i have tried manual as well more like a flash but it will not allow and says the firmware is incorrect plese get firmware again and make sure it is the correct firmware for this product and i was trying to do satlite first
- Jeepfreak1983Apr 29, 2018Guide
ok so I have got the flash to work I also went back to 2.1.2.18 both satellite and router the issue i had with file type was i checked the satellite box and uploaded it in the router box nex im try to work on blocking auto updates seen this.
https://community.netgear.com/t5/Orbi/Firmware-V1-12-0-18-Discussion/td-p/1320421/page/5
this has been a nightmare. I am very thinkful for this community as i was pulling my hair out over this thank you all for your help
