ModeratelyGeeky
Mar 06, 2019Tutor
Orbi RBW30 Antennas
Are the antennas in the wall plug RBW30 satellites omnidirectional? Does it matter whether they are plugged in vertically vs. horizontally?
CrimpOn
Mar 06, 2019Guru - Experienced User
My brief search did not turn up a "picture" of the RBW30. (I am not a great searcher.)
If you already have one, it should "come apart" easily with a small Phillips screwdriver.
What we think of as an "Omni-directional" antenna typically refers to a "do-nut" shape, where there are distinct "dead zones" at the exact top and bottom.
