ModeratelyGeeky
Mar 06, 2019Tutor
Orbi RBW30 Antennas
Are the antennas in the wall plug RBW30 satellites omnidirectional? Does it matter whether they are plugged in vertically vs. horizontally?
Mar 07, 2019Guru - Experienced User
Here is what the RBW looks like inside:
https://apps.fcc.gov/eas/GetApplicationAttachment.html?id=3333993
- CrimpOnMar 07, 2019Guru - Experienced User
Is there a secret to get access to this web site? I get a "Not Authorized".
- FURRYe38Mar 07, 2019Guru - Experienced User
Hmm worked yesterday,
Try this then select Internal Photos:
Thanks for the link to pictures. It appears to me that there are two sets of antennas at the top. One set oriented vertically and the other horizontally. So, it might not make any difference which direction the RBW30 is plugged in.
