adhodgson
Mar 10, 2019Aspirant
Orbi RBW30 brakes Plex uPnP
Hi,
My setup is an RBR50, 2 RBS50 devices and an RBW30. I have had an issue with Plex whereby UPnP stopped working meaning I couldn't use my Sonos system with it, and when checking the logs I ...
ekhalil
Mar 10, 2019Master
Likely since the RBW30 was added to the network and for somereason the UPnP portmap table was not propagated from the Router to the RBW30.
I guess deactivating UPnP in the web GUI and activating again should fix this issue. Have you tried that? :)
adhodgson
Mar 11, 2019Aspirant
Hi,
I tried that as I have issues with syncing devices before - a few months ago when making changes I ended up with the guest wireless enabled on one of the sattelite units in the default state even though I never touched the guest options. In any case it doesn't make any difference although I have it working now by making sure the Plex server starts up before the RBW30 is switched on. I do get the errors in the Plex log once the device is turned on (I can duplicate here if required), but the remote access is working now at least. Last night I factory reset all the units and did the setup of all units from the initial setup wizard.
Thanks.
Andrew.
- FURRYe38Mar 11, 2019Guru - Experienced User
You might have two uPnP servers online instead of one. There should only be one, ether on the Orbi or on the Plex, You might try disabling either uPnP on the Plex and see if this helps. If uPnP is enabled on the Orbi Plex will keep working.
adhodgson wrote:
Hi,
Thanks.
Andrew.
