lms84
May 28, 2020Follower
ORBI RBW30 causing repetitive network crash with Router RBR50
Hi I suddenly started having a contant reboot of my router RBR50 this week. My system is composed of a RBR50, a RBS50 and 2 RBW30. I manually updated the firmware of all the units to the lat...
Jun 17, 2020Guru - Experienced User
Any progress on this?
lms84 wrote:Hi
I manually updated the firmware of all the units to the latest version as of May 27, 2020, made a factory reset on all units and reconfigured the system again.
After a few minutes working, the issue persisted and the wifi crashes restarted.
I then tried to have only the router working without any problems. Then I added the RBS50 and it also worked fine. As soon as I added the RBW30, within 10 minutes the wifi network started failing again.
I am now working with one staellite only, which fails to cover the whole house, and have to useless RBW20's.
Can anyone offer some help?
Thank you!
