wimmme
Sep 20, 2019Tutor
Orbi RBW30 not connecting roomba
Hello, i have a pretty hybrid Orbi system. This works very well for smartphones, tablets and pc's, but one exception is my Roomba 960 Robot vacuum. My house has 2 levels, and one corner is served...
Sep 20, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Can try lowering the power out put of the wifi radios on the RBR, try 75 or 50%. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
wimmme
Sep 23, 2019Tutor
Thank you for your answer. experimenting with some settings now.
310 sq meters (3300 sq ft), distance varies from 12m to 6m, depending on the walls (thick brick walls, al ot of concrete and piping).
Connections between them are good. roaming i working fine for other devices.
Fixed 2.4 channel, there are 2 or 3 other signals but not that strong.
Will report back
