Whirly's avatar
Whirly
Orbi RBW30 satellite keeps dropping connection
I bought this last week and I set it up. It links (blue light) but then when I go to check it a little later it's not connected. It's doubly annoying because everything connected to it loses internet...
  • FURRYe38's avatar
    You can find RB40 FW here:
    https://www.netgear.com/support/product/RBK40.aspx#download
    Your way behind and you may not beable to upgrade fully to most current unless you apply an intermediate version of FW first. I would try
    Version 2.1.1.12,
    Then once this is applied, then apply v.210.
    I recommend downloading the files first, the useing IE11 or FF browser, apply the intermediate vresion, then most current version, do a full factory reset then setup from scratch.
    If you update to recent FW v.210, enable Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
    Whirly wrote:
    Hmm, I tried the firmware update, it says "No new firmware version available" on both the router and satellite.
    RBR40 Firmware: V1.9.1.6
    RBW30 Firmware: V2.2.1.204
