dstranathan
Jun 07, 2018Apprentice
Orbi RBW30 Satellite questions...
I just added a new RBW30 to my new Orbi CBK40 kit (a CRB40 modem/router combo and a RBS20 satellite). I was able to add/sync the RBW30 to my existing network fairly easy.
A few questions regard...
Jun 07, 2018Guru - Experienced User
I would disable the RBW30 and use the CBR40 and RBS20 satellite. Even this is probably more than enough for coverages and load balancing for bandwidth. I have this same system, use only the 1 satellite and everything I have connects fine in my 5000 sq ft home two story with basement. 40 feet in between the router and satellite.
