rickcandle87
Jun 06, 2017Aspirant
Orbi Re-Installation
I had a lot of trouble getting the orbi and satellite set up initially. I now need to power down and relocate the satellite and disconnect the cable feed to the modem upstream of the router. Que...
DarrenM
Jun 08, 2017Sr. NETGEAR Moderator
Hello rickcandle87
After setup they should just pair back up when powered on only way you would have to do set up again is if the units got factory reset.
DarrenM
