JD15
Feb 04, 2021Aspirant
Orbi reading lennox iComfort thermostat as a Satellite
My lennox iComfort S30 will not connect to my Orbi network and I think this may be why. It looks like the Orbi is trying to read it as a Satellite and not as a device that wants to connect to the...
JD15
I'd like to now go into the SSID list on the iComfort and then select my SSID and see if it connects that way (instead of the workaround way of manually building the SSID), but I'm not messing with it. Someone else can experiment on that!
Thanks for the help!
vajim
Feb 04, 2021Master
JD15 wrote:I'd like to now go into the SSID list on the iComfort and then select my SSID and see if it connects that way (instead of the workaround way of manually building the SSID), but I'm not messing with it. Someone else can experiment on that!
a better way to check would be to simply go to the lennox at the wall and click and click to settings and somewhere in there it should show you the SSID its connected to. you may not need to select ot change anything
