JD15
Feb 04, 2021Aspirant
Orbi reading lennox iComfort thermostat as a Satellite
    My lennox iComfort S30 will not connect to my Orbi network and I think this may be why.  It looks like the Orbi is trying to read it as a Satellite and not as a device that wants to connect to the...
fmalloy
Feb 04, 2021Luminary
Is it possible the Lennox unit tried to connect to the backhaul channel, which would make the Orbi think it's a satellite?
I had an issue with a NETGEAR WiFi dongle connected to my satellite dish box. In the dish box network setup, I saw two SSID entries for 5GHz (same string), and two for 2.4GHz (same string). I wondered why there would be two...
- vajimFeb 04, 2021Master
 fmalloy wrote:Is it possible the Lennox unit tried to connect to the backhaul channel, which would make the Orbi think it's a satellite? I had an issue with a NETGEAR WiFi dongle connected to my satellite dish box. In the dish box network setup, I saw two SSID entries for 5GHz (same string), and two for 2.4GHz (same string). I wondered why there would be two... Thanks I think the original poster is good to go
