scegg
Sep 27, 2018Aspirant
Orbi reboot every time when upper link disconnected logically (not physically)
Hello.
Here is my network at home:
Modem -- Router (WNDR3700v4) for dialing up -- RBR50 -- (wifi) -- Satellite
Orbi is set as AP mode. Some devices are connected to RBR50 by wire, some...
- Oct 06, 2018
You would have to try a different router in place of the 3700 to see if the problem happens if connected to the WAN port.
Sep 27, 2018Guru - Experienced User
What FW is currently loaded?
Disable ALL wifi radios on the WNDR3700, configure the WNDR3700 DMZ for the IP address the Orbi router gets from the WNDR3700. Set a IP address for the Orbi routers IP address it gets ON the WNDR3700. Then try using the Orbi router in Router mode.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6. Save settings and reboot the router and satellite(s).
scegg
Thanks for your reply.
Firmware version is 2.1.4.16.
All radios on WNDR3700v4 are disabled already. coz I just need it as a dial-up router with some LAN service. DMZ setup of WNDR3700v4 is preserved for my main home computer -- there are some apps I used daily not support UPNP.
And actually, there is NO WAY to setup the IP of the Orbi when it set as AP mode, funny? It just keep to use the original one gotten while it set as router.
The size of my home is around 800 sqft. No more than 30 ft between router and satellite. When router works, the connection speed between them are fast enough (> 50 MBytes/sec) and stable.
2.4GHz is set to auto. 5Ghs is on 36. There are several WiFi nearby, around 5-8.
The problem is the router reboots while re-dial up on WNDR3700v4. Even all LAN-based computers conencted to the router are reported disconnected.
- FURRYe38Sep 27, 2018Guru - Experienced User
I would presume that there maybe a problem with the 3700.
I would try the DMZ for the Orbi as a test to see if it changes anything. You can revert back if it doesn't work.
Have you tried the Orbi router in router mode in place of your 3700? It's got PPPoE support as well.
- sceggSep 27, 2018Aspirant
So what magic power the 3700 has, to make the orbi reboot, and only orbi reboot...
I'll test your plan later. There are some devices connected to the 3700 directly, which won't be affected as orbi.
I was planned to use Orbi as a replacement of 3700. But the sad thing is my NAS will send alarm email when the LAN is physically disconnected. To avoid receive those junk every day, currently I have to connect it directly to 3700.
You'll have to disregard the NAS messages while the configuration is changed over.
Not sure why the Orbi is rebooting. Try connecting the Orbi router to the 3700 using the LAN port and not the WAN port and see.
