scegg's avatar
scegg
Orbi reboot every time when upper link disconnected logically (not physically)
Hello.   Here is my network at home:   Modem -- Router (WNDR3700v4) for dialing up -- RBR50 -- (wifi) -- Satellite Orbi is set as AP mode. Some devices are connected to RBR50 by wire, some...
  • FURRYe38's avatar
    You would have to try a different router in place of the 3700 to see if the problem happens if connected to the WAN port.
