scegg
Sep 27, 2018Aspirant
Orbi reboot every time when upper link disconnected logically (not physically)
Hello.
Here is my network at home:
Modem -- Router (WNDR3700v4) for dialing up -- RBR50 -- (wifi) -- Satellite
Orbi is set as AP mode. Some devices are connected to RBR50 by wire, some...
- Oct 06, 2018
You would have to try a different router in place of the 3700 to see if the problem happens if connected to the WAN port.
scegg
Thanks for you idea.
Now I use LAN, instead of WAN, on Orbi to connect it to 3700. Let's see whether it reboot tomorrow. I'll update it.
BTW, when I switch the cable, the Orbi is not rebooted. The light of the router turns red but the satellite doesn't. Now all clients on satellite can still access the internet but in the webpage of Orbi, no satellites listed at all (all devices connected to satellite are listed as connection type - unknown.
scegg
Now one more problem found:
When WAN port is not used on router, the router will always light as red. Tried reboot, no fix to the light, but fix the satellite displaying.
Network works.
