scegg
Sep 27, 2018Aspirant
Orbi reboot every time when upper link disconnected logically (not physically)
Hello.
Here is my network at home:
Modem -- Router (WNDR3700v4) for dialing up -- RBR50 -- (wifi) -- Satellite
Orbi is set as AP mode. Some devices are connected to RBR50 by wire, some...
- Oct 06, 2018
You would have to try a different router in place of the 3700 to see if the problem happens if connected to the WAN port.
Sep 27, 2018Guru - Experienced User
Yes, the top led will be pink as it's meant to detect the WAN port connection. Its ok if it's Pink. Nothing can be done with it if using the LAN port. I wanted to see if using the LAN port would show a different result.
