scegg
Sep 27, 2018Aspirant
Orbi reboot every time when upper link disconnected logically (not physically)
Hello.
Here is my network at home:
Modem -- Router (WNDR3700v4) for dialing up -- RBR50 -- (wifi) -- Satellite
Orbi is set as AP mode. Some devices are connected to RBR50 by wire, some...
- Oct 06, 2018
You would have to try a different router in place of the 3700 to see if the problem happens if connected to the WAN port.
scegg
Okay, I leave it as using LAN till next re-dial up. I'll update the result here.
Thanks.
Sep 27, 2018Guru - Experienced User
Sounds good.
- sceggSep 27, 2018Aspirant
It doesn't reboot this time, with LAN port used instead of WAN.
Any idea?
- FURRYe38Sep 28, 2018Guru - Experienced User
Possible some odd handshaking happening with the 3700 that causes the Orbi to reboot when connected to it's WAN port. Just speculation. You would have to try a different router in place of the 3700 to see if the problem happens if connected to the WAN port.
- sceggOct 06, 2018Aspirant
FYI: 2.2.1.210 does not fix this
