scegg
Sep 27, 2018Aspirant
Orbi reboot every time when upper link disconnected logically (not physically)
Hello.
Here is my network at home:
Modem -- Router (WNDR3700v4) for dialing up -- RBR50 -- (wifi) -- Satellite
Orbi is set as AP mode. Some devices are connected to RBR50 by wire, some...
- Oct 06, 2018
You would have to try a different router in place of the 3700 to see if the problem happens if connected to the WAN port.
scegg
It doesn't reboot this time, with LAN port used instead of WAN.
Any idea?
Sep 28, 2018Guru - Experienced User
Possible some odd handshaking happening with the 3700 that causes the Orbi to reboot when connected to it's WAN port. Just speculation. You would have to try a different router in place of the 3700 to see if the problem happens if connected to the WAN port.
- sceggOct 06, 2018Aspirant
FYI: 2.2.1.210 does not fix this
- FURRYe38Oct 06, 2018Guru - Experienced User
- sceggOct 12, 2018Aspirant
Tested with other routerS.
While re-dial up, some router's IP will not be reachable by ICMP echo testing (ping). Working with these routers, orbi will reboot. If the ping to the main router can be passed without problem, orbi will not reboot.
