scegg
Sep 27, 2018Aspirant
Orbi reboot every time when upper link disconnected logically (not physically)
Hello.
Here is my network at home:
Modem -- Router (WNDR3700v4) for dialing up -- RBR50 -- (wifi) -- Satellite
Orbi is set as AP mode. Some devices are connected to RBR50 by wire, some...
- Oct 06, 2018
You would have to try a different router in place of the 3700 to see if the problem happens if connected to the WAN port.
scegg
Oct 06, 2018Aspirant
FYI: 2.2.1.210 does not fix this
Oct 06, 2018Guru - Experienced User
- sceggOct 12, 2018Aspirant
Tested with other routerS.
While re-dial up, some router's IP will not be reachable by ICMP echo testing (ping). Working with these routers, orbi will reboot. If the ping to the main router can be passed without problem, orbi will not reboot.
- FURRYe38Oct 12, 2018Guru - Experienced User
Seems that would be a host router issue I believe as we don't see this issue with Orbi connetions with Cable, DSL or FIOS ISP services.
