adubsizzle
Oct 14, 2018Aspirant
Orbi Reboot Required - New Arris Touchstone TG2472
Bend Broadband just "upgraded" my modem to an Arris Touchstone TG2472. Since then, I have to reboot my Orbi every time I want to use the internet. It makes it tedious to watch Netflix :)
The Arris has the "Enable Wireless" unchecked for both 2.4 and 5GHz...
Any thoughts?
- adubsizzleAspirant
After a bunch of research I figured out I needed the Modem to be in Bridge mode which can be done by following this link:
https://arris.secure.force.com/consumers/articles/General_FAQs/TG862G-NA-Bridge-Mode-Setup
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
