IAmBruceK
Sep 24, 2018Tutor
Orbi recently became very slow.
We have been having ~115M-120M speeds on my Orbi up until the past week or so. Now I am seeing ~20M max and a TON of timed out connections. The speed is poor on both wireless and wired connections....
Sep 25, 2018Guru - Experienced User
I would try this since I don't believe you have as of yet, factory reset the RBR router and set up from scratch. Just run thru the set up, I would first skip configuring the wifi and adding a satellilte. Just get thru the wizard, then do a speedtest via ethernet with the connected PC and see what the results are. If after this the speed is still low, I would revert back to prior working FW and try that...If that still fails, possible HW failing on the RBR...
IAmBruceK
Sep 25, 2018Tutor
I mentioned I had done a factory reset in the missing post I mentioned earlier. As of now I have done 3 resets as you described. The only change I see is that I went from my initial ~20M speed to ~30M after the first reset.
Previously I had 2.1.4.10 installed and the speed was good up until last week. I am doubtful that restoring it will resolve the issue though. I can certainly try it or I can go back to 2.1.3.4 even. I will hold off on doing this another day just to see if anything else can be done. (I'm leary of reverting router firmware due to bricking 2 in the past with firmware reverts. Maybe Orbis are more tollerant though.)
- FURRYe38Sep 25, 2018Guru - Experienced User
You can down grade, just manually download the files and use IE11 or FF browser when doing it.
If nothing help with this, I presume there is a problem with the Router portion of the system and would need to be looking into further by NG support. Only other thing I can think of would be to take it to a different location, say friend, family or neighbors and see if the problem follows. If it does, then you'll have your answer. Not much else I can think of other than to RMA it.
