Tias
Jun 03, 2019Tutor
ORBI redirecting to login page
Hi community and support, from time to time, without me changing anything, the ORBI (maybe just the satellite) stops connecting to webpages. Instead it reroutes everthing to its own login page and g...
- Jul 03, 2019
OK, so today I bought a little PCIe ethernet adapter, connected this and now the wired network seems to work again.
This is itself is positive of course but I would really like to understand what is going on there with the old ethernet adapter.
Thanks for all the ideas and tips.
Tias
Jul 02, 2019Guru - Experienced User
Try a different network adapter card in the PC if possible.
Try a USB to LAN adapter as a suggestion.
Sounds like this issue is a PC problem, not with the Orbi.
Tias
Jul 03, 2019Tutor
Tias
- FURRYe38Jul 03, 2019Guru - Experienced User
Old adapter probably going bad.
Mark your thread as solved.
Good Luck.
