cccccccc
Jun 14, 2020Aspirant
Orbi regular FTTC internet drop outs
Regular internet drop outs. Comes right after a while eg 5 minutes, or if I restart the power to the NBN box and router. No logged outages at Aussie Broadband when they put a trace on. All lights ok...
Jun 15, 2020Guru - Experienced User
Is the ISP modem in router mode or modem only mode?
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Can the ISP router be removed?
Try the Orbi in AP mode with the ISP router.
- ccccccccJun 15, 2020AspirantFTTC NBN box is directly connected to ORBI, no ISP Modem/Router in between.
Any other ideas?- michaelkenwardJun 16, 2020Guru - Experienced User
cccccccc wrote:
FTTC NBN box is directly connected to ORBI, no ISP Modem/Router in between.The FTTC NBN box IS the modem.
cccccccc wrote:
Any other ideas?Not without useful information.
Is there any reason why you are keeping its details a secret?
If you don't want to answer questions, then just search this community for stuff on NBN. It is a constant theme. Someone has probably been down the same road already.
Search - NETGEAR Communities – NBN FTTC box
Then there is this:
What is an NBN network and is my NETGEAR DSL modem router compatible? | Answer | NETGEAR Support
- ccccccccJun 16, 2020AspirantTo the previous reply, thanks for being sarcastic.
I was asked earlier to configure the ISP providers modem (Aussie Broadband). They did not provide a modem and hence I said my Oribi is connected to the FTTC box. This box has no wifi and is not configurable by me and is used by and ISP I would use.
But hey, thanks again for being sarcastic.
