cccccccc
Jun 14, 2020Aspirant
Orbi regular FTTC internet drop outs
Regular internet drop outs. Comes right after a while eg 5 minutes, or if I restart the power to the NBN box and router. No logged outages at Aussie Broadband when they put a trace on. All lights ok...
cccccccc
Jun 15, 2020Aspirant
FTTC NBN box is directly connected to ORBI, no ISP Modem/Router in between.
Any other ideas?
Any other ideas?
michaelkenward
Jun 16, 2020Guru - Experienced User
The FTTC NBN box IS the modem.
cccccccc wrote:
Any other ideas?
Not without useful information.
Is there any reason why you are keeping its details a secret?
If you don't want to answer questions, then just search this community for stuff on NBN. It is a constant theme. Someone has probably been down the same road already.
Search - NETGEAR Communities – NBN FTTC box
Then there is this:
What is an NBN network and is my NETGEAR DSL modem router compatible? | Answer | NETGEAR Support
- ccccccccJun 16, 2020AspirantTo the previous reply, thanks for being sarcastic.
I was asked earlier to configure the ISP providers modem (Aussie Broadband). They did not provide a modem and hence I said my Oribi is connected to the FTTC box. This box has no wifi and is not configurable by me and is used by and ISP I would use.
But hey, thanks again for being sarcastic.- ccccccccJun 16, 2020AspirantThe NBN FTTC Box is a Netcomm NDD-0300 connected to my RBR50
- FURRYe38Jun 16, 2020Guru - Experienced User
Do you have the ISP router that may have been provided? Might hook this up in between and use the DMZ on this router for the Orbi. Or set AP mode on the Orbi and see if this problem still happens in either configuration.
