dsharla's avatar
dsharla
Follower
Nov 18, 2020
ORBI Relocation
Can I relocate an ORBI RBK50 from a permanent home to a vacation home?  Are there any issues I need to consider?
  • CrimpOn's avatar
    Nov 18, 2020
    Yes, of course.  There is a good chance that you can simply connect the router to the modem and it will work immediately.
    If the vacation home has a totally different type of internet connection (such as PPoE), you may need to do a Factory Reset and configure the Orbi: https://www.youtube.com/watch?v=cMw4ePACgc4
