pralfano
Feb 10, 2019Aspirant
Orbi Remote Access with Alexa
How do I setup remote access with Alexa?
- Feb 10, 2019Have you already setup Alexa to work with Orbi using the following steps:
To enable the NETGEAR skill:
1. Enable remote management on your router, use the Orbi app to enable remote management.
2. Enable the NETGEAR skill in the Alexa app.
3. When the Alexa app prompts you to sign in, use the same NETGEAR account credentials that you previously used in Orbi app.
Once you have done that Alexa will have remote access to Orbi and you will be able to control Orbi when at home or remotely.
ekhalil
Feb 10, 2019Master
