pralfano
Feb 10, 2019Aspirant
Orbi Remote Access with Alexa
How do I setup remote access with Alexa?
- Feb 10, 2019Have you already setup Alexa to work with Orbi using the following steps:
To enable the NETGEAR skill:
1. Enable remote management on your router, use the Orbi app to enable remote management.
2. Enable the NETGEAR skill in the Alexa app.
3. When the Alexa app prompts you to sign in, use the same NETGEAR account credentials that you previously used in Orbi app.
Once you have done that Alexa will have remote access to Orbi and you will be able to control Orbi when at home or remotely.
ekhalil
Feb 10, 2019Master
Koceto
Feb 11, 2019Aspirant
Hello Ekhalil,
Can you please tell me if you need evry time to say “ Alexa Tell Orbi to……..(and then the command)
I see that some routers are controlled with those words “Tell…. and then router name..And then the command”
Is Orbi controlled like that or is the ordinary way saying only “Alexa, switch of my bedrooms lamps” for example?
- ekhalilFeb 11, 2019Master
Koceto wrote:
.......Can you please tell me if you need evry time to say “ Alexa Tell Orbi to……..(and then the command)
I don't have Alexa but have Google Home devices. I need to say "Hej Google, ask Netgear to ..... (then the command)".
I also have Harmony (TV remote hub) integrated with Google Home, and for Harmony I used to say "Hej Google, ask Harmony to ..... (then the command,)" but recently Harmony did an update and I now can say "Hej Google, ...... (then the command)" directly, so I hope that Netgear will also do an update to it's Alexa and Google skills to be able to do this shortcut.
- pralfanoFeb 11, 2019Aspirant
I do NOT need to ask Alexa to ask ORBI to command. I can just say "Alexa, turn on the bedroom lights."
This depends on the level of integration of the service or application with Google Home or Alexa, for some service you can just say "Alexa do this" but for other apps you still need to say "Alexa, ask "app" to do this". The same goes for "Hey Google"
- KocetoFeb 11, 2019AspirantThanks guys.
I got it now. I thought that this depends on what model router you buying, but obviously is not like that. It depends on how much each brand is integrated if I got it correct. I will prefer to skip the part when I need to say "Alexa tell Netgear......and then the command ". So that's what I wanted to make clear. Is any other model more integrated into Alexa or all models in that Brand are in the same level. So then I can go and buy the one which I prefer as Orbi RBK 50 AC3000.
