Chuck_M
Jan 14, 2019Mentor
Orbi Remote Management INOP
I am having issues through the Orbi App with enabling and conducting remote management
W hen I run the orbi app outside of my LAN, here is the initial screen:
In this case I am on a exte...
- Jan 14, 2019
Interestingly enough, after multiple reboots and turning on and off remote management... it started working through the Orbi App.
Thanks much.... have no clue why it suddenly came alive!
ekhalil
Jan 14, 2019Master
How does the settings in the app look like? You need also to activate it in the app. Not enough to do it in the GUI. This is how it's done in iPhone:
Chuck_M
Jan 14, 2019Mentor
Will advise as soon as I get home!
- Chuck_MJan 14, 2019Mentor
The App has it (and had it) enabled as well as the GUI... but it says it is disconnected as per the image above.
The serial number is correct but there is a red dot next to the router name (RBR50).
Any other thoughts?
I CAN web access the router GUI remotely but the Orbi App doesnt work.
Any other thoughts?
- ekhalilJan 14, 2019Master
Any other thoughts?
1. Can you please also try from the Genie app. Go to Remote Management --> Enter your netgear account email and password and then enable Remote Management.
2. Please also check under >>ADVANCED>>Administration>>Logs>> if you see any remote access activity events when you try to login so we know if the remote login attempt was at all reaching to Orbi.
