Chuck_M
Jan 14, 2019Mentor
Orbi Remote Management INOP
I am having issues through the Orbi App with enabling and conducting remote management
W hen I run the orbi app outside of my LAN, here is the initial screen:
In this case I am on a exte...
- Jan 14, 2019
Interestingly enough, after multiple reboots and turning on and off remote management... it started working through the Orbi App.
Thanks much.... have no clue why it suddenly came alive!
Chuck_M
Jan 14, 2019Mentor
Will advise as soon as I get home!
Chuck_M
Jan 14, 2019Mentor
The App has it (and had it) enabled as well as the GUI... but it says it is disconnected as per the image above.
The serial number is correct but there is a red dot next to the router name (RBR50).
Any other thoughts?
