steeve725
Mar 12, 2019Guide
Orbi remote management shows wrong model
Hi, Everyone Had my orbi system for a few days and really like it. Just dealing with what I think is another bug. Yesterday when I was away from home my remote management wasn't working. Wh...
ekhalil
Mar 13, 2019Master
steeve725 wrote:
Yes, it shows correctly
I'd try the following:
- To deactivate the product and then register it again.
- After that go to the Orbi app and click on Home and then NEW SETUP and scan the QR code of the router and follow instructions.
steeve725
Mar 13, 2019Guide
Ok.
That shouldn't affect anything else should it? Then when I go into the app and new setup and scan the qr code it should be OK?
- ekhalilMar 13, 2019Master
I think you should be fine. I just tried the product deactivation and then registration and worked fine.
After you do this chek the issue is solved, if not then try the NEW SETUP in the app.
I believe also that the NEW SETUP in the app with QR code should also be ok, I've done it many times! :)
- steeve725Mar 13, 2019Guide
Well I tried new setup in the app after product deactivation and then registration didn't work.
Wow what a mess. I tried new setup, scanned qr code, unplugged modem, router, unplugged both satellites, replugged everything back in. Waited for everything to power back on. In the app, Orbi then asked me to join the default network SSID that came with my Orbi. I clicked join. I get the message unable to join. It then tells me go to the wifi settings on my phone, find and connect to the orbi SSID found on the product label. My Iphone cannot find the SSID for the Orbi. I click on other under the wifi names listed since the orbi isn't showing up to try and input manually, that wont take either.
I guess the re-set up isn't going to work for me.
Sorry for the mess. It usually goes smooth for me! :)
Again I think that the issue is in the NG database and I hope that Christian_R will help with that. :)
- steeve725Mar 13, 2019GuideHi.
It was taken care of by Christian
Thank tiu
