Pflipper
Oct 31, 2017Aspirant
Orbi Remote Management trouble
Hi, I want to set up my Orbi to be accessed and managed remotely. Is this possible? I am trying the Netgear genie desktop app for my PC, and it keeps failing, " NETGEAR Genie has stopped workin...
st_shaw
Oct 31, 2017Master
Try to set it up by logging into the Orbi's admin GUI at the IP address of the router.
Pflipper
Nov 01, 2017Aspirant
Just tried to reinstall the software from this site:
https://www.netgear.com/home/discover/apps/genie.aspx
When I opened the software, same issue. I am all up to date with Windows 10 updates as of Nov 1, 2017.
Anyone out there have thoughts on why this is happening. Is the software useless?
- st_shawNov 01, 2017MasterI guess what I wrote wasn’t clear. I meant you should use the Orbi GUI to setup remote access and management. I would forget about the Genie. I never use it myself.
- PflipperNov 06, 2017Aspirant
OK - what is the "Orbi GUI" you are talking about. Is it a desktop app? I have the Orbi mobile app, and there is no remote management tool. Are you saying that I need to plug into the Orbi using an ethernet cable from my laptop and open something on the actual device in order to set up a way I can remotely access the Orbi. More specific information would be helpful.
Thanks!
- Retired_MemberNov 06, 2017
Pflipper wrote:OK - what is the "Orbi GUI" you are talking about. Is it a desktop app? I have the Orbi mobile app, and there is no remote management tool. Are you saying that I need to plug into the Orbi using an ethernet cable from my laptop and open something on the actual device in order to set up a way I can remotely access the Orbi. More specific information would be helpful.
Thanks!
The Orbi GUI runs on the built in Orbi web server and can be accessed via a web browser.
