Pflipper
Oct 31, 2017Aspirant
Orbi Remote Management trouble
Hi, I want to set up my Orbi to be accessed and managed remotely. Is this possible? I am trying the Netgear genie desktop app for my PC, and it keeps failing, " NETGEAR Genie has stopped workin...
Pflipper
Nov 06, 2017Aspirant
So, specifics... "can be accessed via a web browser". So can most anything connected to the internet. If you are familiar with navigating to this, it seems so apparent, so simple. If you are unfamiliar (like me) with navigating to this and setting up things on the Orbi, you either need a good instructions (which doesn't seem to be available) or clearer direction.
Is the Orbi web server you are referencing found at "http://orbilogin.net". I can access that, go to the advanced tab, look at remote mangement, but what to I need to set up exactly. I have a laptop I want to use to access my Orbi network remotely. I'm guessing that I select "Turn on remote managment", then click on "Only this computer", but then it is asking me for my IP address. When I access a network from a remote location, isn't this going to change depending upon where I am? Is so, how is selecting an IP address going to help. If I select "allow access from everyone", then I am opening up a path to my Orbi to everyone that is going to be less secure. Again, this may be simple to you if you've set it up before, but it would be more helpful to me to get either direction of better instructions from Netgear.
Thanks for any additional help!
martinhj
Nov 07, 2017Luminary
What you say is correct.If you enable remote management then anyone can access your Orbi if they know our admin username and password, hence the instruction to change the password to something secure. And also the instruction to change the port. But anyone who scans your ports would find it and then possibly be able to get into it if they can guess your username/password. You are right that you can restrict this to particular IP address or range but that would change depending where you login from. Unless you really need remote management I would NOT enable it and work on your theory that you have obviously thought about of less is best.
if you really want remote access maybe a better option would be to configure the orbi to allow VPN access (User manual Chapter 9 - Use VPN to Access Your Network) .This wasyy you have the added level of security of the VPN tunnel negotiation being more than just a simple username/password pair. Ou get the benefit of then being able to logon to your home network remotely as if you were connected at home. You could argue having a means of accessing your whole network is worse but if someone has found a route into your router they afre going to be able to see all your network devices and open u our router anyhow. If someone really wants to get in they will do.
The downside of the vpn is that you may not be able to access your home network via vpn depending where you are if the remote network ou are attached to (eg our workplace) blocks the ports used b the vpn. But then that would probabl also block your standard remote access unless you use the standard http or https port anyhow.
