granvillea
Sep 06, 2019Guide
Orbi repeatedly drops Internet after Firmware Update
I have an Orbi RBR50 Router and 2 RBS50 Satellites configured with the Router in Center of Home and Satellites in 2 Directions from Router. I updated the Firmware today to V2.3.5.30 and now I am dropp...
granvillea
Sep 06, 2019Guide
In addition, I have checked with ISP and they show no issues and if I connect directly Sans Router I have no issues. I use OpenDNS and GoogleDNS as my DNS Servers and have set that each time I have Factory Reset the Orbi’s. I used the Orbi IOS App to update the Firmware on all three Orbi devices and the Router and 1 Satellite took the Firmware Update fine, the 2nd Satellite showed Update Failed on 1st try but showed ok on 2nd Attempt. That was only issue on update other than immediately creating the Dropping Internet Connection I am querying about.
Sep 06, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Try downloading the FW file for the RBS from NG support site and manually install the FW file to the RBSs web page
