dguilloryjr's avatar
dguilloryjr
Orbi reset
So me and the wife were out of town this week and my kids call and say the internet is out. I talked my daughter through getting things back online, but here's my question:
What makes the Orbi RBR50 do a self reset?
When my daughter facetimed me there was a white ring on the router. I had her log onto my PC and go to the router page, it was asking to go through initial setup! We had to re-enter SSID/Password set questions for forgotten password, etc. We literally went through a full initial setup.
Thoughts ideas? Is there anything I can do to figure out why this happened?
  • plemans's avatar
    Could have been a firmware upgrade, or a power surge that cause boot issues, or something else.
    Tough to know after the fact
    • dguilloryjr's avatar
      dguilloryjr
      Is there a way to turn off the auto updates on a RBR50? I don't see a way to do that but if this was the cause of the issue, I would rather just turn off the auto updates.
      • plemans's avatar
        there used to be away and then they took that away and made them all auto-update. I know there was talk of re-enabling the disable auto update but I'm not sure if its rolledout yet
