CharAp
Jul 17, 2018Follower
Orbi restart issues
Looking at the Netgear Orbi as a mesh wifi solution. Very good reviews all over the place but I also saw the following at TechRadar (https://www.techradar.com/reviews/netgear-orbi):
Second, should ...
tsig
Jul 17, 2018Luminary
I have turned off breakers powering the satellites and routers together and separetly and have had a power outage. Everything behaves as expected once power is restored. Sorry if this bust anyone's bubble.
- RocketSquirrelJul 21, 2018Luminary
We all have different setups and different problems. For example, I'm using wired backhaul, and guessing that makes recovery from power outages more problematic. I imagine the Orbis power up looking for wireless backhaul first.
My bubble is still intact. Now if someone replies their wired Orbi system restores perfectly after a power outage, POP!
- waynealightJul 21, 2018Apprentice
i have similiar issues and I also put both my orbis on ups backups. I can restart them fine if they are wireless but ethernet backhaul creates another issue. If i have to restart I will unplug ethernet backhaul, restart both systems and let them sync. then plug ethernet back in. Its the most efficient was I can do it. This only happens if I'm changing firmware or a major network change that requires me to unplug the router. The backup keeps everything up and running with no issues.
- cvoiseyJul 22, 2018Guide
I am experiencing the same right now. The problem is that I can't get signal to all parts, so it sounds like I have the exact same problems. Wired backhaul is horribly implemented.
- Retired_MemberSep 29, 2018
We appear to have the same issue, After rebooting the router, we have to hard reset the satelites with a needle.
Looks like double IP numbers are issued and.or the DHCP is not well implemted...
any tips?
- FURRYe38Sep 29, 2018Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the IP modem the Orbi is connected too?
any tips?
