Conl6430's avatar
Conl6430
Orbi RK23 not a trusted source for iPhone X with ios14
since the download of ios 14 i can not connect my iphone to the orbi app, and when on wifi i can not go to any websites, says the site can not provide a secure connection.  if i go off wifi everything works fine.
  • Do you have access control enable? iOS14 have what Apple name "Private Address" witch assign a dynamic MAC address per Wi-Fi network.
    There is a lot of discussion on the net about this and several threads in the forum.
    One fix I remember is for you to reset your network settings on the iPhone.
    If you search the net, there are more solutions to follow.
      • Mikey94025's avatar
        Mikey94025
        Hero
        Conl6430 wrote:
        thanks i will try the network settings approach.
        Yes, this happened to me too.  It seems to be an iOS14 bug with existing wireless connections.  I just fiddled with forgetting the existing wireless connection and then toggling the Private Address switch off and then back to on.
