markrich21
Oct 09, 2022Aspirant
ORBI RKB50 & Motorola DOCSIS 3.1 modem
I upgraded my Motorola 3.0 DOCSIS to a new 3.1 DOCSIS but have failed to get wifi xmit with ORBI. I called optimum (Suddenlink) and they see the modem and successful transmission on their end. Then...
- Oct 15, 2022
Yes. Orbi supports any WAN connection that uses ethernet RJ45 connection.
Be sure your using good quality LAN cable between the modem and RBR. CAT6 is recommended.
Check with the ISP to see if there is any special configurations other than DHCP needed to be set on the Orbi system. Most Cable ISP use DHCP however could be something special needed.
If you connect a wired PC to the modem and power cycle it, does it get internet services thru the modem? If it doesn't, then it could be the modem. Connecting the RBR to the modem should use same power cycle on the modem to get it to connect to the RBR.
Oct 10, 2022Guru - Experienced User
What Firmware version is currently loaded on the Orbi system?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
If the old modem is working and the new one doesn't, sounds like something the ISP needs to look into.
markrich21
Oct 15, 2022Aspirant
Tried to reconnect the new modem and same issue so reconnected old modem and it works. ISP says they can see the new Motorola DOCSIS 3.1 modem receiving and sending. My RBR50 has firmware v2.7.4.24 and indicates no update available.
Seems to me to be a Netgear ORBI problem. Would be great if someone could say yes that system can't handle either the DOCSIS 3.1 config or output. Sucks I have to return modem ...
- FURRYe38Oct 15, 2022Guru - Experienced User
