steinmr
Apr 07, 2019Tutor
Orbi RKB53 global differences
Is there any difference between Orbi RBK53 sold in the US and in Europe? Any differences in supported bands, interference etc.? Or are they interchangable? Planning on buying in US and using in Norwa...
SW_
Apr 11, 2019Prodigy
When you boot/setup Obri router in EU or any other regions, it will figure out the correct region automatically. If not, it can still be changed, but you might be running afoul with local channels.
For example, this shows that it can be changed and all the supported regions.
michaelkenward
Apr 12, 2019Guru - Experienced User
No.
That may apply to hardware bought in the EU, or anywhere outside the USA, but it is not the case for hardware supplied directly from the USA.
The drop down that shows the region is not available on my Orbi devices. It is there on the R7800 router.
I suspect that there are ways to Telnet into the router to change the settings, but I haven't found them.
