steinmr
Apr 07, 2019Tutor
Orbi RKB53 global differences
Is there any difference between Orbi RBK53 sold in the US and in Europe? Any differences in supported bands, interference etc.? Or are they interchangable? Planning on buying in US and using in Norwa...
ekhalil
Apr 12, 2019Master
REGION read:
root@RBR50:/# artmtd -r region
The region number is: 0x0002
REGION: WW
REGION wirte:
Usage: artmtd -w region "region name"
For instance : artmtd -w region NA
The REGION name can only be "NA,WW,GR,PR,RU,BZ,IN,KO,JP,AU,CA"
michaelkenward
Apr 12, 2019Guru - Experienced User
Thanks to ekhalil and FURRYe38 for those ways to "cheat" the system. I will copy the details and file them away just in case someone at Netgear decides to remove this seditious information!
- FURRYe38Apr 12, 2019Guru - Experienced User
:smileyvery-happy:
