steinmr
Apr 07, 2019Tutor
Orbi RKB53 global differences
Is there any difference between Orbi RBK53 sold in the US and in Europe? Any differences in supported bands, interference etc.? Or are they interchangable? Planning on buying in US and using in Norwa...
michaelkenward
Apr 13, 2019Guru - Experienced User
SW_ wrote:
Here are some update pictures to show that region can be changed via Orbi's UI to Europe, Australia, and back to North America.
Perhaps you are missing the point. Where did you get your hardware from?
The ability to change region depends on several factors. Not least being the geographical source of the hardware. Mine came directly from the maker in the USA. That's why I have so much of this kit.
The laws in Europe and Australia are very different from those in the USA. That's why we need the EU to tame the likes of Google. So stuff that we can change is blocked in devices sold in the USA. Maybe its a Trump thing.
I own an RBR40, RBS40V, RBW30 and RBS50Y. As others, including SW_, have confirmed, the drop down to change the region is blocked in the RBR40 and RBS50Y, as in it does not work.
Fortunately, thanks to SW_, FURRYe38 and ekhalil and Telnet, I managed to change the RBR40 so that it now enables the drop down.
It seems that setting the region to 0x0001 disables the dropdown. Changing it to 0x0002 means that it now works.
It hasn't been that straightforward with the other Orbis, but they work so I am not busting a gut to dig deeper.
SW_
Apr 13, 2019Prodigy
michaelkenward wrote:
>> Perhaps you are missing the point. Where did you get your hardware from?...
Not sure why you still think I am missing the point. I can show you another screen shot where it's disabled on my Orbi. Also, if you are curious, my Orbi set was purchased from Costo in the US and I live within a driving distance of Netgear HQ. :-)
If it helps, here is a screen shot before where it's disabled. The reason I enable it on my Orbi was only to help OP and let him know it's okay to purchase from Costco bring it back home to save some money.
- michaelkenwardApr 14, 2019Guru - Experienced User
(Embedded pictures needs approval, attached files go straight through.)
Something seems to have got lost in translation. To sum things up:
If you buy an Orbi system in the USA, then when you take it home to Europe, for example, there is a good chance that you will not be able use that dropdown to change the wifi region. (And, contrary to what someone said earlier, the hardware does not recognise where you are and change the wireless region accordingly.) It simply does not work for the devices that I listed earlier. The region shows as North America. The drop down is "greyed out". No can change.
If you want to see the dropdown then, as you said earlier, you have to jump through some hoops to get it to work. I followed the guidance from ekhalil.
I wasn't going to mention this, but my Orbi devices came from the Netgear HQ.
- SW_Apr 14, 2019Prodigy
>> the hardware does not recognise..
It's NOT the hadware, it's software, which has the smart to recognise the right vs. wrong region.
You seem to answer your own question here.
>> It seems that setting the region to 0x0001 disables the dropdown. Changing it to 0x0002 means that it now works...
>> And, contrary to what someone said earlier...
That *someone* is me. You can say it. :-)
SW_ wrote:
>> When you boot/setup Obri router in EU or any other regions, it will figure out the correct region automatically. If not, it can still be changed, ..
Case and point here or check out the pictures in this post.
When you figure out the reason behind changing region from 0x0001 to 0x0002, which the Orbi UI (software) suddenly allows you to access to drop down menu to change the region, then you will have a different perspective of what I said above.
>> If you want to see the dropdown then, as you said earlier, you have to jump through some hoops to get it to work...
I didn't have to jump through hoops to enable it on Orbi RBK53 set, because it's something I already knew a while back. Like many of us (myself included), simply asking the right question, as the steinmr did at the begining of this post, will often get the answers we're looking for.
To find the region light switch, just put 2 and 2 together. The answer you seek is often right in front of us.
I rather not speculate on things that I don't know the answer to.
