steinmr
Apr 07, 2019Tutor
Orbi RKB53 global differences
Is there any difference between Orbi RBK53 sold in the US and in Europe? Any differences in supported bands, interference etc.? Or are they interchangable? Planning on buying in US and using in Norwa...
MarcusVR
Sep 24, 2019Tutor
Hi guys!
I live in Brazil and bought a RBK53 set from USA Amazon, now running the firmware
V2.3.5.30. I followed the steps to access other regions, but the range of channels available didn't change - it is locked to the range from 36 to 48 in 5Ghz band - and, after a reboot, the option was locked again. I'd like to use upper channels in 5Ghz. Some tips?
Thanks in advance!
michaelkenward
Sep 24, 2019Guru - Experienced User
MarcusVR wrote:
I followed the steps to access other regions...
How did you do it?
The US models I received did not have a region drop down. I had to perform "magic" on the things.
- MarcusVRSep 24, 2019TutorMine have a drop-down, but it is grayed and not responsive to clicks. The telnet instructions made it clickable and allowed me to change the region to South America just after a page refresh, but it didn't affected the wifi channels available and after a boot the drop-down was grayed again.
- michaelkenwardSep 24, 2019Guru - Experienced User
MarcusVR wrote:
Mine have a drop-down, but it is grayed and not responsive to clicks.That's the dreaded "locked in" syndrome.
I wonder if the telnet thing stuck. It did here.
Try again?
- MarcusVRSep 30, 2019Tutor
Hi!
Using firmware 2.3.5.30 I followed the instructions and got the functional drop-down menu, but the 5 Ghz channels frequency can't be changed.
- FURRYe38Oct 01, 2019Guru - Experienced User
To change channels, you can change them user Basic/Wireless settings. Not under Advanced/Wireless settings.
MarcusVR wrote:Hi!
- MarcusVROct 01, 2019Tutor
Thanks FURRYe38, but the upper channels aren't available neither there. I can choose only between 36, 40, 44 and 48!
Ya we know. Those are the only 4 channels on 5Ghz NG allows. The higher channels 149 thru 161 are reserved for the wireless backhaul only. Not user configurable.
MarcusVR wrote:Thanks FURRYe38, but the upper channels aren't available neither there. I can choose only between 36, 40, 44 and 48!
