steinmr
Apr 07, 2019Tutor
Orbi RKB53 global differences
Is there any difference between Orbi RBK53 sold in the US and in Europe? Any differences in supported bands, interference etc.? Or are they interchangable? Planning on buying in US and using in Norwa...
michaelkenward
Sep 24, 2019Guru - Experienced User
MarcusVR wrote:
Mine have a drop-down, but it is grayed and not responsive to clicks.
That's the dreaded "locked in" syndrome.
I wonder if the telnet thing stuck. It did here.
Try again?
MarcusVR
Sep 30, 2019Tutor
Hi!
Using firmware 2.3.5.30 I followed the instructions and got the functional drop-down menu, but the 5 Ghz channels frequency can't be changed.
- FURRYe38Oct 01, 2019Guru - Experienced User
To change channels, you can change them user Basic/Wireless settings. Not under Advanced/Wireless settings.
MarcusVR wrote:Hi!
- MarcusVROct 01, 2019Tutor
Thanks FURRYe38, but the upper channels aren't available neither there. I can choose only between 36, 40, 44 and 48!
Ya we know. Those are the only 4 channels on 5Ghz NG allows. The higher channels 149 thru 161 are reserved for the wireless backhaul only. Not user configurable.
MarcusVR wrote:Thanks FURRYe38, but the upper channels aren't available neither there. I can choose only between 36, 40, 44 and 48!
