Swat1871's avatar
Dec 23, 2020
Orbi RKS bricked after update
Hi folks
I have an syno 218j NAS
after using 2.6.1.40 I could`t reach the NAS
updating to 2.7.0.70 same problem
after downgrading the satellite didn´t start
he is bricked
I want to install firmware via tft64, but my LED is green, not orange
Can anyone help?
    • vajim's avatar
      vajim
      Master
      Is this another case of firmware update gone bad?
      • <rant mode on>
        It is unbelievable (and unacceptable) that Netgear has to publish such a "backdoor" way of fixing their failed firmware updates!  It is their fault for not developing a robust update process.
        They should replace systems under warranty when this happens with released non-beta firmware updates
        <rant mode off>
  • So were you able to get your RBS working with the suggestion? Looks like it...
    Swat1871 wrote:
    Hi folks
    he is bricked
    Can anyone help?
      • vajim's avatar
        vajim
        Master
        Please mark your thread as Solved so others will know.
