Chuck14472
Jan 31, 2020Follower
Orbi RMW30
I purchased the Orbi RBW30 after my Nighthawk stopped working six months past the expired. It worked well for about 3 months and then all of the Orbi wall plug stopped connecting.
I’ve rebooted the router many times and the wall plugs appear to connect for an hour and then disconnect. My support is not expired and I have no idea how to solve this problem.
Chuck
1 Reply
- tomschmidtVirtuoso
Since your system is still under support, then please contact Netgear support and open a ticket. You can report back here to the community with your findings.
Good Luck
