Retired_Member's avatar
Retired_Member
Oct 17, 2016
Orbi router - Can I create a VLAN on the WAN port?
I have CenturyLink's 1 gigabit fiber optic Internet service. CenturyLink requires VLAN 201 set on the WAN port. Can I do this with the Orbi router?
If the Orbi router does allow this, my only concern is if the router will actually push through gigabit speeds via the wired connection to my desktop. A lot of routers don't. Right now I'm using the Asus AC3100 and it stays pretty true to my gigabit Internet. I get about 900Mbps down/up when running SpeedTest.net.
  • the asus rt-ac3100 is 2156M on 5 gig
    the orbi is 867M on wifi
    what do you think is going to be the conclusion
    • Retired_Member's avatar
      Retired_Member
      Ya, that's not what I asked at all! I want to know about the WAN port and if I can create a VLAN on it. My ISP requires me to set a VLAN of 201 on the WAN/Internet port. Simply entering my PPPoE credentials and password is not good enough.
      I'm not asking about wifi at all.
      • peteytesting's avatar
        peteytesting
        Hero
        no vlan as there isnt on most netgear stuff
        plus its too slow for 1000M plans anyway
    so as you see even the best wireless router money can buy atm wont give you the full 1000Mbps because of the wan to lan throughput bottleneck and the orbi wont ether ( in router mode )
      Retired_Member
      Let's be real. If I'm getting 900+Mbps for my down/up speed, it could 1 of 2 things. Either the router or possibly the server I'm running my speed test from can't push out the full 1000Mbps. However, I could care less. If I'm getting 910Mbps down/up on a gigabit connection, I'm happy.
      THIS IS 100% BESIDES THE POINT THOUGH! Seriously dude, I'm not here to argue about gigabit speeds and talk about speed.
      I simply came to this forum to find out if the Orbi would allow me to set a VLAN of 201 on the WAN/Internet port. THAT'S IT!
        peteytesting
        Hero
        i have already said there is no vlan controls that i know of
        and your initial statement in the second paragraph you stated
        "my only concern is if the router will actually push through gigabit speeds via the wired connection to my desktop"
        which the answer is it wont
        so you just out of luck in both cases
        pete
