Desmond_Lau
Jun 07, 2017Star
Orbi Router - QOS Setup
When I go to QOS setting, only see "Speedtest - powered by OOKxx", When I click the speedtest button, it will take a long time to run. After that, I go to Satellite to check "Connected Device", the ...
shwnwllms
Jun 07, 2017Tutor
QoS is disabled when Orbi is set to AP mode:
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
Do you have Orbi set up as a Router or in AP mode? If you have it set to AP mode the speedtest is all that will show up under QoS as everything else is disabled.
- Desmond_LauJun 07, 2017Star
No, my Orbi Is router mode,
- rbk50Jan 28, 2018Tutor
When will Netgear fix this?
Seems a persistent problem even in router mode, I only have access to do a speed test on the QoS page, nothing more.
