Desmond_Lau
Jun 07, 2017Star
Orbi Router - QOS Setup
When I go to QOS setting, only see "Speedtest - powered by OOKxx", When I click the speedtest button, it will take a long time to run. After that, I go to Satellite to check "Connected Device", the ...
Mestegall
Aug 01, 2017Star
If in your browser you enter the following after you log in - it will show a QoS page.
/QOS_dynamic.htm
However - when I try this I'm not able to actually "Apply" those settings.
Anyone know how to solve that?
BravoRomeo
Aug 01, 2017Initiate
I was able to Apply change on that /QOS_dynamic.htm page by very carefully hovering the mouse on the bottom edge of the Apply button. It seems the page is unfinished and untested. Nevertheless, after hitting Apply I received a dialog about sending my MAC address to "the provider", then had to check the Dynamic QOS box again and hit Apply a seccond time. It stuck. No idea if it actually works. I'm about ready to use Orbi as an access point and move to Mikrotik for more capable routing.
- MestegallAug 01, 2017Star
While I was finally able to click "apply" thanks to your advice - I'm still not able to see where/how we can set the priority of how devices are connected to the internet. I have a wireless CPI camera (security) and often it keeps 'dropping' the wifi signal. There seems to be no rhyme or reason as to when this happens. I'd like to make it a higher priority to see if that will fix the problem.
Any ideas?
